[XenGenTr] Forum statistics system english full by thxf.org
addon 2.2 [XenGenTr] Forum statistics system english full by thxf.org 4.0.5
ไม่มีสิทธิ์ดาวน์โหลด
เวอร์ชัน XF ที่เข้ากันได้
  1. 2.1
  2. 2.2
การสร้างแบรนด์ที่มองเห็นได้
  1. ไม่
You have already used a different version of this statistic. I am happy to release the new version with some requests and the necessary changes.
This Modiffy not want English patch
Demo 3.1.5 :
Demo 4.0.0 :
[XenGenTr] statistics - Technical specifications
  • It is a widget system with Tamami.
  • New, recent messages.
  • New issues.
  • The subjects that received the most reply.
  • Most viewed topics.
  • Top rated topics.
  • You can withdraw the above data from the required forums in any number of times.
  • 1 user statistic requested.
  • User names appear in user group colors.
  • Topic link next to Google search button.
  • The change in the database works without any new additions.
  • Of course 100% Mobile compatibility.
  • And it is from TURKISH :)
[h4]Options of the insert[/h4]
  • User groups that can view attachments can be restricted.
  • Unwanted widgets such as new topics, messages, hit topics can be turned off.
  • Member Stats On / Off.
  • Open / Close in user name group color
  • Google search button on / off
Visual options;
  • You can arrange all the area colors of the insert as you like.
You will see more as you use it :)..
Plugin installation;
If you are using the old statistic, you must remove it. I did not want to deal with that change with updates to The complete structure.
Installation;
Step 1,
- Pull the file from the attachment
Step 2,
- Into the folder named UPLOAD in the file into the folders with the same name in the FTP
Step 3,
- Adminpc >> Add-ons >> find add-ons >> Upload with install button
Settings;
- Admincp >> Groups and permissions >> User group permissions >> Group to authorize >> [XenGenTr] Forum statistics permissions
- Adminpc >> Installations >> XF options >> [XenGenTr] Forum stats - Options
- Adminpc >> Views and languages >> Theme properties >> [XenGenTr] stats - Design
ทรัพยากรที่เกี่ยวข้อง
ผู้เขียน
การดาวน์โหลด
8
การเปิดตัวครั้งแรก
การอัปเดตล่าสุด
การให้คะแนน
0.00 ดาว 0 การให้คะแนน
ไฟล์เพิ่มเติมจาก thxf.org
อัปเดตล่าสุด
  1. update 4.0.5
    Improvements have been made to the LESS Structure. For mobile systems, the sorting area has been...
  2. 4.0.4 update
    Improvements have been made to the LESS Structure. For mobile systems, the sort field has been...
  3. 4.0.3 update
    4.0.3 Update content; - Statistics display positions have been added to the theme properties...
