- เวอร์ชัน XF ที่เข้ากันได้
- 2.3
- ข้อกำหนดเพิ่มเติม
- xf 2.x : https://www.thxf.org/resources/xengentr-prefix-system.98/
[XenGenTr] Prefix design system
Go beyond the default xenforo prefix designs with this add-on we developed for XenForo 2.3. You can use any of the "15" stylish designs integrated into the add-on and change them whenever you want.
Important information : If you are using the old prefix system, unfortunately you will no longer be able to use those prefixes in this version. If you wish, you can delete your old prefix plugin and make new edits. Or you can update and make changes to your old prefixes one by one . |
