[XenGenTr] Forum statistics system english full by thxf.org
addon 2.x [XenGenTr] Forum statistics system english full by thxf.org 4.0.3
ไม่ได้รับอนุญาตให้ดาวน์โหลด
เวอร์ชัน XF ที่เข้ากันได้
  1. 2.1
  2. 2.2
ลบแบรนด์ที่มองเห็นได้
  1. ไม่
You have already used a different version of this statistic. I am happy to release the new version with some requests and the necessary changes.
This Modiffy not want English patch
Demo 3.1.5 :
Demo 4.0.0 :
[XenGenTr] statistics - Technical specifications
  • It is a widget system with Tamami.
  • New, recent messages.
  • New issues.
  • The subjects that received the most reply.
  • Most viewed topics.
  • Top rated topics.
  • You can withdraw the above data from the required forums in any number of times.
  • 1 user statistic requested.
  • User names appear in user group colors.
  • Topic link next to Google search button.
  • The change in the database works without any new additions.
  • Of course 100% Mobile compatibility.
  • And it is from TURKISH 🙂
[h4]Options of the insert[/h4]
  • User groups that can view attachments can be restricted.
  • Unwanted widgets such as new topics, messages, hit topics can be turned off.
  • Member Stats On / Off.
  • Open / Close in user name group color
  • Google search button on / off
Visual options;
  • You can arrange all the area colors of the insert as you like.
You will see more as you use it 🙂..
Plugin installation;
If you are using the old statistic, you must remove it. I did not want to deal with that change with updates to The complete structure.
Installation;
Step 1,
- Pull the file from the attachment
Step 2,
- Into the folder named UPLOAD in the file into the folders with the same name in the FTP
Step 3,
- Adminpc >> Add-ons >> find add-ons >> Upload with install button
Settings;
- Admincp >> Groups and permissions >> User group permissions >> Group to authorize >> [XenGenTr] Forum statistics permissions
- Adminpc >> Installations >> XF options >> [XenGenTr] Forum stats - Options
- Adminpc >> Views and languages >> Theme properties >> [XenGenTr] stats - Design
ไฟล์ที่เกี่ยวข้อง
เจ้าของ
ดาวน์โหลดแล้ว
4
อ่าน
2,156
เวอร์ชั่นแรก
อัปเดตล่าสุด
เรตติ้ง
0.00 star(s) 0 ความนิยม
ไฟล์เพิ่มเติมจาก thxf.org
อัปเดตล่าสุด
  1. 4.0.3 update
    4.0.3 Update content; - Statistics display positions have been added to the theme properties...
  2. 4.0.2
    [XenGenTr] Forum statistics 📊 system V4 🥳 Innovations; ✅ All options have been moved to the...
ด้านบน ด้านล่าง
